Big misfire issue please help
Old Jun 6, 2019 | 09:22 PM
corbin bryant's Avatar
Default Big misfire issue please help
The beginning of the week, i finished my cam, injectors, springs, pushed, and longtube install. The car fired up and ran great. I have been breaking it in pretty good, taking it easy except for 3 or 4 quick rips. Today I fired it up, and it seemed to try to flood itself out, but i revved it up and it went away, but when i got on the road and got it above 4000 rpm, it stsrted missing. I habe no idea why. Is it a defective injector? Loose rocker bolt, ruined cam, ruined engine? Should I unplug the battery and reset the ecu? I'm freaking out and have no leads at all. Any input would be a huge help. Thankyou
Old Jun 6, 2019 | 09:24 PM
B52bombardier1's Avatar
What do your spark plugs look like? Oil fouled? Sooty black?
Rick
Old Jun 6, 2019 | 09:31 PM
I dont know i havent pulled any yet. I replaced them when i did the job. But thats a great idea. I dont know why I didn't think of that
Old Jun 7, 2019 | 07:20 AM
Old Geezer's Avatar
How about following up on your other ideas.
Like pull the valve covers, etc.
Old Jun 7, 2019 | 08:08 AM
vettenuts's Avatar
You don't mention tuning in your post.
Have you tuned it? If not, I wouldn't be driving it much especially if you went bigger on injectors because you may be washing the oil off your cylinder walls.
Old Jun 7, 2019 | 08:10 AM
blkbird's Avatar
This!
Old Jun 7, 2019 | 08:12 AM
Laddimyr's Avatar
Make sure you didn't melt a plug wire somehow lol. Also check all of your plugs, I've had one crack while doing headers before that didn't start arcing until a week or so after. And do you have the car tuned, or did you just install the cam/injectors and start driving it around tuneless?
Old Jun 7, 2019 | 08:19 AM
LilJayV10's Avatar
You mentioned injectors in your list. As others said, if you but bigger injectors in it. Don't run it anymore. You're gonna kill it.
Old Jun 14, 2019 | 05:14 PM
gMAG's Avatar
What is the nature of the “missing”. Does it seem to miss intermittently...a cylinder miss here and there? Or does the car stumble, and bog down? I’m thinking electrical/continuity/wiring issue. Because the car ran ok to your liking, before, I don’t think that the tune is your issue, although with your mods, you require a tune.
