Removing rear cover questions
When removing the rear cover, do I need to replace the rear main seal? Gaskets? I'm sure it's a good idea to do that but was just wondering if it's absolutely necessary. I don't see any oil leaking from it. I was just wanting to pop the cover off, look at the back of the cam then bolt it back in place.
Even if you tried to get away with it chances are the rubber is hard and will never seal back correctly
