Oil pump selection
Old Jun 28, 2019 | 06:24 PM
Z28MEXICO's Avatar
Talking Oil pump selection
Hello everybody..
actually im bulding a LS1 for re install on my 2002 z28, already have a 799 ported heads with dual springs, titanium retainers and a BTR stage 3 camshaft..
but i need a oil pump to lubricate my new internals.. so... what OIL PUMP is best ?? HIGH PRESSURE OR HIGH VOLUME?
thanks a lot
Old Jun 28, 2019 | 08:01 PM
Hi pressure. Hi volume is not needed for any stock non-VVT, non-DOD/AFM engine with stock clearances.
Old Jun 28, 2019 | 08:19 PM
SLP IROC-Z's Avatar
depends on your clearances
Old Jun 28, 2019 | 11:08 PM
Re-read my post above yours. Yes, with looser clearances you would need a higher volume of oil. Stock clearances, normal oil volume.
Old Jun 28, 2019 | 11:16 PM
sjsingle1's Avatar
i have a HP HV pump.....no problems.....jus sayin
Old Jun 29, 2019 | 07:01 AM
KCS's Avatar
KCS
Moderator
Melling 10295 (high pressure) will be fine. I only use the 10296 or 10355 (high volume) pumps when the bearing clearances are loosened up.
Old Jun 29, 2019 | 07:28 AM
Holy Diver's Avatar
High pressure would be my recommendation.
