5.3 with gen 4 valve clearance?
Old Jul 1, 2019 | 08:31 AM
jigggawatt's Avatar
Default 5.3 with gen 4 valve clearance?
I’ve read through lots of posts and still have a question. I’m putting together a gen 3 with gen 4 rods and flat top pistons. The engine is out of a 04 Yukon. I’ve had it rebalanced. I’m using stock heads and cam. I wondering if I should clay the piston to valve clearance, or will I be ok with the stock cam and heads.
Old Jul 1, 2019 | 11:00 AM
You should be fine. Gen IV rods are the same length as Gen III
Old Jul 1, 2019 | 11:52 AM
jigggawatt's Avatar
Even going with flat tops?. Thanks for the help
Old Jul 1, 2019 | 01:15 PM
ALL LS rods except 4.8 and LS7 are the same length. If they are stock flat tops there should be no issue.
Old Jul 1, 2019 | 01:18 PM
jigggawatt's Avatar
Thank You
