Urgent help needed!!!!
Old Jul 16, 2019 | 06:22 AM
Mike Cordero's Avatar
Default Urgent help needed!!!!
I bought a 4" K1 crankshaft from another member and due to a poor box/wrapping, the 24 tooth ring bents but was replaced in a machine shop. Right now I'm planning to use a 58 teeth ring and my question is: if I make some marks in the crank with the present 24 teeth ring, using those marks I can place the 58 teeth in the same place and that will be ok? Timing will be right?
Old Jul 17, 2019 | 01:01 PM
Default crankshaft ring
Bump. Still looking for info.
Old Jul 17, 2019 | 02:14 PM
ss4chad's Avatar
That's what I did, works fine.
Chad
Old Jul 17, 2019 | 09:30 PM
01CamaroSSTx's Avatar
http://www.superchevy.com/how-to/eng...-your-ls-crank
