Colapsed Lifter possibly??
Old Jul 13, 2004 | 04:56 AM
soundengineer's Avatar
Default Colapsed Lifter possibly??
So I just got done putting in patriot gold dual springs on my X1 cam 97000 mile car......
is the spring pressure too high on the patriot duals for my lifters?
I put an Idle up to temp heat cycle on them.....
decided that heat cylce #2 was going to be highway driving... below 2000 rpm's on my way out to the Girlfriends house.....
so I started driving...and about 15miles into it ( 65mph 6th gear 1500ish rpm's) I hear this ticking...that is getting louder...and now is a clacking sound...
cant seem to localize it.....looked under the valve covers and didn't see any broken springs..... and I dont thinkl it is loud enough to be a spun bearing...from what I understand that sounds like the motor is coming apart when that happens.....and my noise is just a clacking that speeds up with rpm's
Old Jul 13, 2004 | 05:03 AM
SSLS1's Avatar
check and make sure your rocker bolts are tight, also might wanna check and see if you have a bent pushrod, if they both are good a collapsed lifter is always a possibility
Old Jul 13, 2004 | 05:07 AM
I have hardened pushrods...and my car was silent before the spring change
rocker bolts are tight... double checked them when I pulled the valve covers to check to see if it was a broken spring
Old Jul 13, 2004 | 06:36 AM
PREDATOR-Z's Avatar
Well 97K is a lot so that could be possible. Try to Isolate which side.
What kind of rockers do you have?
Old Jul 13, 2004 | 10:26 AM
harland sharp rockers... they are tight.....
Old Jul 13, 2004 | 11:16 AM
PREDATOR-Z's Avatar
How much did you torq them?
But did you check if the harlands were hitting the retainers. I've read a couple of threads when they made contact on spring retainers that are slightly larger than stock.
Old Jul 13, 2004 | 09:22 PM
Kenny D's Avatar
I had the same problem with the man. Threw a lifter in the oil pan.
