Head and Cam cracked a ring or broken piston.
Old Jul 26, 2019 | 06:42 PM
raymond mckinney's Avatar
Default Head and Cam cracked a ring or broken piston.
About 3k miles ago I did some Prc 13 degree 227s, hollow valve's, milled to 59cc, tsunami cam, flyout, 1 7/8 headers, ported fast 92 and all the bolt ons. Timing is 28* degrees and no signs of knock when tuning. Afr was around 12.1-12.4 wot.
Bore camera shows no sign of cracks on any pistons but # 7 failed a leak down and only 90psi.
Thinking about putting another stock piston in and throwing it back together. I just don't want another issue. Anyone have an answer why this may have happened?
My c5z has been running a similar setup since 2004 with no issues but AFRs and g5x3 cam.
Old Jul 26, 2019 | 09:13 PM
99 Black Bird T/A's Avatar
Well that sucks that #7 was 90# and failed leak down.
Had the same thing happen with a junkyard LS1, I bought a long time ago. Likewise had a 90# leak down. We pulled heads and found, it already had a stock replacement piston in the #7 hole So yes putting a stock replacement in can work sometimes. However, by the time the LS1 got to me it needed to go .005 over to get a good seal.
Noticed that Afr was around 12.1-12.4 wot. Is thatlittle on the rich side?
Most NA LS seem to be in the 12.5 to 13.1 range. I'm not a tuner so hopefully the experts at Tuning will comment.
FWIW no answer on #7 but here's a theory - The way it was once explained to me: #7 may see a little less airflow but gets the same amount of fuel so sometimes #7 is richer. That may cause #7 to run a hair hotter than the other cylinders because it's tad richer than the average cylinder. Same amount of fuel, but less air, so richer. Richer = hotter as a result
Old Jul 26, 2019 | 10:30 PM
s30.hybrid's Avatar
Low cylinder pressure could also be caused by bad sealing of the valves. A bent stem, burned valve or worn seats could give similar results. Are you able to hear where the air is leaking to during your testing?
Old Jul 27, 2019 | 10:10 AM
No air coming back threw the intake. Motor has 24k miles and 2k on the Head and Cam. 12.4 is alittle rich but the car ran good and pulled like a freight train so we left it alone. I was thinking maybe a touch too much timing with the 13 degree heads being more efficient? I will drop the heads off to get the valves checked when the motor comes out.
Old Aug 2, 2019 | 10:07 AM
David@Vengeance's Avatar
I would agree with this assessment, while 27-28 can be fairly normal on a factory headed Ls1, moving to a more efficient head usually reduces timing as its more efficient.
