6.0 Build Questions
Also, you mentioned your tune is much better than your last tune, are you tuning it yourself or just found a better tuner to do it?
I like the way your build sounds, I think for what I’m doing, if using your setup, I’d go with a cam slightly milder than what you’ve got now, maybe a 220/226, lessen valve overlap between intake and exhaust valves a little more. To be completely honest, I had to play it back a couple times to get a good listen as my attention kept getting drawn to the blue C4 in your garage as you’d pan the camera around. Gosh I miss that car.
I know you mention the heads are already ported due to it coming off an H2 motor that used a blower, do you think the stock 317s would make any difference to what you have now since they appear to flow pretty well already? Probably just keep the power curve on the lower end, yea?
The 4L65E - how has that done with the lift and 33’s you have now? Any issues with it so far, and is it stock or did you have it built for the application? How difficult was it to make it work with the LQ4?
Since you mentioned you’re using electric fans, how are your temps in the city in traffic? I was planning on keeping the mechanical pump since the airflow is supposed to be way better while moving than the electric fans (8000-10000cfm compared to the 4000cfm of most good electric fans). What radiator are you using for cooling?
1) The tuning software/interface is more intuitive/clean with the holley, in my opinion
2) I have less items in the SW 'fighting' or modifying the end results. I had lots of issues where I spent time trying to figure out what in the SW was pulling timing. Better tuners wouldn't have issues here probably, but understanding all of the connections between high octane table, low octane table, knock retard, burst knock, etc. I didn't like it.
3) Closed Loop, even in wide open throttle, the Holley is always watching/correcting.
4) Fuel - learn. I *could* do this functionally the same with my HP TUners and my wideband, but there, I'd drive with a laptop, log data, get the histograms, adjust the tables, reflash. With the Holley, most of those steps are automatic, and I just click a box to transfer the learning trims to the base map. Which brings to:
5) I don't need a laptop in the car. I can do all of my datalogging / recording onto an SD Card, and then play back my drive at home on my laptop. It's a convertible, with no locking top, so it's a benefit to not need my laptop with me, for rain and theft reasons. I can always grab a datalog when I need it, without planning ahead.
6) When I *do* play bag the log files, you can watch the SW and it shows you which cells it was running in your maps. So if I see a lean spike, it shows me the fuel, spark, VE tables right then, and I can watch it move around in the playback. This is a real benefit for someone like me learning
7) When I Want to, I also *can* bring my laptop, and now watch the tune running live on the screen. And I can do live tuning, and adjust values on the fly if needed.
8) I have multiple tunes on my SD card, which is on the 3.5" handheld in the car. So I have multiple tunes, and they are very fast to load/switch between. So I can make changes, but still have my one file called "Known good tune", and if I don't like my latest file, I can just swap back, again, without any laptop.
I have the 3.5" handheld mounted under my dash so it isn't really visible unless you are in the car. And not so theft-worthy as a laptop.
If I had a car with other CAN communication to the cluster and body controls, I'd consider a factory ECU, but in my case, there was no reason not to switch
https://www.advanceadapters.com/prod...onadapter-kit/
My blue one is slow (LT1 + 4L60). My Jimmy is faster than it for sure, at reasonable speeds. Those 2.59 gears at to blame. I think all LT4 cars were 6 speeds with 3.45 gears. If I toss my Dana 44 rear with 3.33s in, it's wake it up. Bought it to LS swap the car, just never did it. Funny, how there isn't much LS swap activity with those things. I like the styling, size, and visibility better than later generations. Of course, I graduated high school in 1992, which is why I got my 92 BAM...
When going to a supercharger on a used likely high mileage motor, wouldn’t it be a good idea to do springs, pushrods, gaskets etc anyways?
Is the difference of long term reliability and wear and tear considerably different between the NA and FI setup?
As far as getting a motor goes I would ONLY get the drivetrain from a wrecked truck, and preferably less than 200k that way you know it was in running condition before you got it.
If its local pull a valve cover and check for sludge.
Sounds like your not wanting to do F/I but with low boost say 7-8psi with good tune, and air to water inter cooler the reliability would be better than having to rev the engine higher to get the same power.
