Dyno Test: Single Pattern VS Split Pattern Cam
Old Sep 13, 2019 | 05:54 PM
wannafbody's Avatar
Originally Posted by Kfxguy
I'm confused as to why its surprising that more duration on the exhaust picked up power. I mean i'm no professional, but You'd think anytime you free up flow, there would be more power produced. Like going from manifolds to headers. I've never seen any engine make more power with choked up manifolds vs headers....to me this is pretty similar, just increasing flow a different way.
(I THINK) Only if the lower duration cam can't evacuate the cylinder of spent gases. An efficient exhaust port vs a less efficient exhaust port, the less efficient port could use more duration.
Old Sep 13, 2019 | 08:27 PM
Right! Especially with the LS rectangular port head, where the exhaust port is much smaller in proportion to the intake, compared to the cathedral heads.
Old Sep 13, 2019 | 09:20 PM
Bspeck82's Avatar
Or could it be that the longer exhaust duration contributes to more scavenging of the intake into the cylinder thus allowing more efficient cylinder filling at higher rpms making more power, and that the exhaust port isnt inefficient per say but more efficient at lower rpms and because we cant add more valves so we make them hang open longer, consequently hurting idle quality and vacuum. Just rambling.
Old Sep 14, 2019 | 05:32 PM
00pooterSS's Avatar
It's not that extremely different really. Cathedrals have around a 76 percent exh to intake flow rate vs 70 percent on the squares. They both suffer the same thing, one just a hair more.... suffrage.
Old Sep 14, 2019 | 05:34 PM
00pooterSS's Avatar
After reading the super chevy article JoeNova posted I don't think I would want square ports in a situation where I was going to have to make a choice.
They made within a couple of horse power of the square ports same cam and using FAST 102 intakes, but the cathedrals should be a bit more fun of a driver head.
