What shims to use for setting preload??
Old Jul 13, 2004 | 08:45 PM
destroyerSS's Avatar
Default What shims to use for setting preload??
I'm going to set up the preload for my new comp r's along with a new set of harland sharp RR's and i'm not sure where to buy theshims or what exactly to order. Should i order the square or round shims? I saw some in Jegs but i was not sure which to get or if they were correct. Thanks Shawn
Old Jul 14, 2004 | 08:48 AM
Steve Burger's Avatar
LS1TECH Sponsor
I used Ford SVO shims. They are square but round will work as well. Jegs and Summit carry them.
Old Jul 14, 2004 | 11:03 AM
KGSloan's Avatar
i used round shims. the square ones will work fine. my only advice is make sure you get them in .015 incriments. the first set only had .030" and .060" shims and i needed .045" worth of shim. as you can see this created a problem. good luck to you
Old Jul 14, 2004 | 11:40 PM
Are you sure that the square shims can be used with Harland Sharps?
Old Jul 15, 2004 | 08:24 AM
LS1TECH Sponsor
Yes. I have used them for months. It was recommended to use the SVO shims.
