Lsx block bore vs boost
Old Sep 21, 2019 | 01:07 PM
startingstock's Avatar
Default Lsx block bore vs boost
I recentlybought a used lsx block from a member here. He was under the impression the bore was around 4.120. Turns out its gonna take a min. 4.170 piston. Not due to rough cylinders. It just had a bigger piston in it than he realised. He got the block from a friend. I cant find a shelf piston smaller than 4.185. And from what I have read/heard, that's too thin for any moderate boost. I was thinking about a custom piston, but is 4.170 gonna be worth it? Will that .015 thousandths make the block that much stronger? Or will I still be rolling the dice with 20 psi ? Any recommendations?
Old Sep 21, 2019 | 03:14 PM
Old Geezer's Avatar
Have it sonic tested before you spend $.10 on it.
