Cam Selection: 228R vs Donald Thump
Old Jan 10, 2020 | 10:29 AM
ddnspider's Avatar
Did the welds on the intake manifold also blow? Stock paper gaskets will hold that motor. Either there was install error or you've got other problems. Did you measure PTV?
Old Jan 10, 2020 | 10:50 AM
jadaven's Avatar
PTV was good. Since I did the install I'll freely admit I may have done something wrong. As far as the intake goes no idea. I left it sitting on the dyno after saying "fix it" and leaving a deposit for repairs.
Old Jan 10, 2020 | 04:08 PM
00pooterSS's Avatar
Besides the headgasket I feel like something is wrong making 440 with a big cam, heads, FAST intake 6 speed car.
Neither one of the cams you have is my favorite for your setup. You could sell them both and pay for a better sized cam for your setup from summit. They are $289. The sum-8707 would be great for your setup IMO or the 8708 for a large cam, but the 8707 is plenty. Or sell them both and add a few bucks for a texas speed or cam motion cam.
I'm just saying you could do a smaller cam and have a much better driving car and make the same or more power. Unless you're going to do everything you need to do to support that big cam. Which you're close, but I wouldn't be using a 3" Y pipe exh. You need lots of compression and flow..
Old Jan 10, 2020 | 07:23 PM
wannafbody's Avatar
I'd do the TSP 228/232 over the 228R. The split duration should extend power a bit higher.
Old Jan 10, 2020 | 07:49 PM
NSFW's Avatar
Was that 440 Dynojet whp, or 440 Mustang whp?
Old Jan 10, 2020 | 08:39 PM
dreadpirateroberts's Avatar
What kind of headgasket and fasteners did you use? How much of a mill did the heads have?
Hard to believe PTV was ok on a cam that big, even if the heads were unmilled.
Old Jan 10, 2020 | 10:15 PM
LilJayV10's Avatar
Does he have heads? If so I missed that part.
Old Jan 12, 2020 | 05:19 PM
00pooterSS's Avatar
I did too at first. But in the fist post it says port and polished 799's
Old Jan 12, 2020 | 08:15 PM
Darth_V8r's Avatar
Moderator
I vote intake killing power
Old Jan 12, 2020 | 11:08 PM
LilJayV10's Avatar
I think that power level on "polished" heads, which means different things to different people...
On an "honest" DJ is Is pretty ******* generous considering the mods and compression,
I won't even talk about MD numbers because no one on the internet uses them because it make your dick feel small.....
Change my mind...
Old Jan 13, 2020 | 12:01 AM
Change my mind...
nahthx i like how u think
Old Jan 13, 2020 | 02:05 PM
  #32
00pooterSS's Avatar
He ended up with a FAST 92 and FAST 92 tb
Not sure if you saw that part
Old Jan 13, 2020 | 02:38 PM
  #33
Darth_V8r's Avatar
Moderator
I didn't. I saw LS6 intake.
Old Jan 15, 2020 | 12:28 PM
  #34
jadaven's Avatar
While I'm still waiting on word back from the shop I can say that if the Donald doesn't drive well it may get swapped. Just not in a hurry to tear it all down.
Correct, they are ported 799s, not milled at all. I was using an MLS gasket with ARP bolts. HP was rated on a DynoJet.
As for what could be holding it back from better numbers, the push rods were too short. When it dyno'd it had 7.5 length pushrods when it probably needs 7.55 Pushrods. I know, it's a weird length. Yes, I measured but obviously not well.
Running a set of COMP 850-16 lifters or maybe the design of the cam are responsible for needing longer pushrods.
It's been a valuable yet expensive lesson so far. So far I've come away with next time let a pro do it.
Old Jan 15, 2020 | 01:19 PM
  #35
00pooterSS's Avatar
Man I hate to hear it went bad but we all go through it man. It's part of building and learning unfortunately. Don't get too discouraged man, the pros weren't pros when they started and they made a lot of mistakes along the way to get where they are. It's just part of it.
Old Jan 17, 2020 | 10:34 AM
  #36
jadaven's Avatar
Thanks. I do tinker around. First time I've done heads though. I've done a cam swap way back on a 4.8 but it was a very small cam, less than the TSP 220. Other than that it's just been normal bolt ons.
This time around I would definitally do things a bit differently. For now ready to get it back drive it some but unfortunatly it looks like winter has finally come to MD.
I'll post an update after everything is sorted out.
Old Oct 31, 2021 | 05:16 PM
  #37
low2001gmc's Avatar
MASS seller approved
So what happened with Donald Thump Cam? Update please...
