Ported 243 + intake or Aftermarket and keep current intake?
Old Oct 29, 2019 | 06:03 PM
FCar2000TA's Avatar
Veteran: Air Force
I wouldnt spend a dime on porting or swapping manifolds. It's not a max effort NA setup, save the money and get the heads/cam right and sacrifice 20-30whp. That money will go towards upgrades/nice to haves when you go boosted.
It will likely be years before I can get the Magnuson, if I ever actually do it.
Old Oct 29, 2019 | 06:17 PM
FCar2000TA's Avatar
Veteran: Air Force
Here is a link to a thread where a guy named PatG put AFR230 on and ditched L92... older thread but PatG.
https://ls1tech.com/forums/dynamomet...k-results.html
Beyond the flow data, the deck thickness and lifetime warranty on the castings since you plan to boost.
I saw that thread. How would that compare to an LS1? 40 less HP?
Old Oct 29, 2019 | 06:18 PM
ddnspider's Avatar
You'll never get there with that attitude!
Old Oct 29, 2019 | 06:26 PM
AINT SKEERED's Avatar
If you honestly plan to stay naturally aspirated for 2years or so, go for as much power as you can now. Worry about a boost set up later. You will be dissatisfied now if you dont
Old Oct 29, 2019 | 08:04 PM
FCar2000TA's Avatar
Veteran: Air Force
Old Oct 29, 2019 | 08:25 PM
Darth_V8r's Avatar
Moderator
I would guess closer than that. With PatG total setup and say only change is short block bore...20-25less? Best guess? I would think 480 is doable without going insane.
Old Oct 30, 2019 | 08:37 AM
FCar2000TA's Avatar
Veteran: Air Force
I don't want to have to measure P2V. Would 231 intake duration be too close?
Old Oct 30, 2019 | 08:57 AM
Darth_V8r's Avatar
Moderator
It should but it will be close and will also depend on intake centerline. AFR ports are higher than 243, so PTV is improved. I ran a solid 237/245-112.5+2, and it was very tight.
Now that 231 intake in a 110 centerline should be ok. On a 107, it would be close. Sorry to be ambiguous, but there are quite a lot of factors, as I am sure you well know.
Old Oct 30, 2019 | 04:35 PM
FCar2000TA's Avatar
Veteran: Air Force
If I can get 450 RWHP through my Dana 60, and just porting my FAST 90 intake (essentially making it a FAST 92), I'll be happy.
Old Oct 30, 2019 | 05:03 PM
Darth_V8r's Avatar
Moderator
I think that is very realistic.
Old Oct 30, 2019 | 05:08 PM
FCar2000TA's Avatar
Veteran: Air Force
We will see how the next few months play out, and see if I get through Income Tax season without needing lube.
Old Oct 30, 2019 | 05:36 PM
  #32
Darth_V8r's Avatar
Moderator
Lol, no ****. It is still wedding season for me.
Old Oct 30, 2019 | 05:38 PM
  #33
I think that's a good goal and I've done 10.91@123 @3850 race weight at 452rwhp through automatic and 12bolt rear
Old Nov 1, 2019 | 06:26 PM
  #34
FCar2000TA's Avatar
Veteran: Air Force
What are the cam specs? I need a cam that plays nice with AC on in 115 degree summers, while driving around parking lot. I think my current cam is 234/235 .590/.610 110LSA. And I really dislike it during the summer.
Old Nov 1, 2019 | 06:32 PM
  #35
FCar2000TA's Avatar
Veteran: Air Force
This is the current setup on the car, minus heads and cam:
Dana 60 with 4.10s
Stage 3 TDP T56 + cryo treated gears
2.5" true duals, dumped at the axle, with cats
FAST 90 intake manifold
92mm to 102mm adapter
102mm Throttle Body
4" MAF housing
LS7 MAF
Custom 4" intake plumbing.
Old Nov 1, 2019 | 07:55 PM
  #36
Was 232/234@.050 .599/.599 112+4
Good tuning helps and as for coolant, good radiator
Old Nov 1, 2019 | 08:11 PM
  #37
FCar2000TA's Avatar
Veteran: Air Force
It isn't engine temps. It is the AC compressor kicking on. The parasitic draw of the AC compressor and power steering pump are enough to make the motor try to die. Even when the tune was spot on, these issues still existed.
Old Nov 4, 2019 | 10:00 PM
  #38
FCar2000TA's Avatar
Veteran: Air Force
I am going to switch to flex-fuel too, hopefully at the same time. I know AZ flex-fuel is only like E54, but that should be significantly cleaner burning, and give at least 5% more power.
Old Nov 5, 2019 | 06:05 AM
  #39
ddnspider's Avatar
If the AC and power steering running make the motor try to die, the tune wasn't spot on.
Old Nov 5, 2019 | 07:11 AM
  #40
Darth_V8r's Avatar
Moderator
Even E30 is enough octane boost to push the timing. Like you said, exhaust should smell notably better.
