LT1 block ?
Old Mar 21, 2003 | 10:42 PM
YBIRD's Avatar
Default LT1 block ?
I have an LT1 block that I want to put a set of Dart Pro 1"s on. I'm way to lazy to mess with the fuel inj. anymore. I know the heads are reverse flow, but what about the block? Isn't it a regular small block chevy with the extra hole for the pump gear? Any knowledge would be appreciated.
Old Mar 21, 2003 | 11:19 PM
zturbo's Avatar
Default Re: LT1 block ?
You are going to have to still do the appropriate changes to the heads to make them work with the lt1 block.
*Oil drain back in the valve spring area
*blocking off the coolant to the intake
and there is a few other little things but I choose to just go aftermarket block instead of use the lt1...
Steven
