2004 lq4 block with 241 heads
Old Nov 13, 2019 | 07:48 AM
andrew perez's Avatar
Default 2004 lq4 block with 241 heads
I’m curious if anyone knows which set of arp bolts I need. I don’t wanna take a guess and get the wrong ones
Old Nov 13, 2019 | 08:09 AM
psicko's Avatar
Depends on the block. Check the block to see if all the larger head bolt holes are equal length or not.
Old Nov 13, 2019 | 10:30 AM
drdave88's Avatar
You'll have to pull the head bolts to make sure. I ran into this on my 04 LQ4 block. It was a later build so all the head bolts are equal length. I wasn't able to use the head studs from the LS1 block I had, which were long/short style. 2 bolts on either end of the head will be shorter than the rest of the bolts. I forget if they are the ones under the valve cover or by the exhaust.
Part numbers for the Hex Head Bolts (not studs)
Early long/short style: 134-3609
Later equal length style: 134-3610
Old Nov 13, 2019 | 11:18 AM
SUPPOSEDLY, 04 LQ4's have the later equal length head bolts, BUT it's still good to check.
