660 plus rockers
Old Dec 25, 2019 | 02:18 PM
Fishmasterdan's Avatar
Default 660 plus rockers
Cant make up my mind. Hoping to get some pros and cons.
Comp cams bsr new shaft rockers vs yella terra rockers.
400# spring pressure 660 lift cam cathedral prc heads. Help me choose. I am really leaning toward the bsr rockers.
Old Dec 25, 2019 | 09:04 PM
wannafbody's Avatar
Someone stated in one of the threads that for the Comp ones to last they need to be plumbed to an oil supply. I'm not sure if that's accurate or not.
Old Dec 26, 2019 | 10:58 AM
I called comp cams and they told me No external oiling required. I also asked about when to go to rollers, they told me to switch to ultra pros at 700 and above open pressure. That I would be fine with the BSR.
No I am more confused. Whats the point of the BSR shaft rockers if the ultra pros are better and cost less?
Old Jan 3, 2020 | 09:36 AM
TurboBuick6's Avatar
Because the stock style rocker is much lighter and has better geometry.
Old Jan 3, 2020 | 10:07 AM
AwesomeAuto's Avatar
Once you switch to a heavier rocker, you have to determine whether or not stiffer valve springs will be needed.
The nose weight of the rocker over the valve tip slows down the valve closing, so you usually need different springs.
This is why I'm not a fan of the Yella Terras and many other aftermarket rockers.
They are very heavy compared to the stockers. Unless they are absolutely needed due to lift, they are a step in the wrong direction.
The BSR rockers are very very nice pieces.
The Ultra Pros are only available in 1.8:1 ratio from what I remember, so putting them on any cam over .590 lift will increase the lift to a point where a roller tip would be required in the first place.
Old Jan 3, 2020 | 12:04 PM
I ordered the BSR rockers under direction of my engine builder. Gonna hit the dyno tomorrow. Hoping to get to 575 to the wheels with cathedrals. We shall see.
Old Jan 3, 2020 | 01:16 PM
Innovate's Avatar
TSP Roller Rockers. I hope the BSR's work out for you!
Old Jan 3, 2020 | 03:26 PM
Jimbo1367's Avatar
I wonder how well TSPs really do work. Meaning how easily they. Go into valve float. They look pretty intriguing.
 Michael S. Palmer
Old Jan 3, 2020 | 03:38 PM
Innovate's Avatar
A good many LS7 guys are using them with good results, mine are not actually on yet. As for valve float, run stronger springs. I swapped to PAC1209x's. Their tip weight is a hair more.
Old Jan 3, 2020 | 03:52 PM
[QUOTE=AwesomeAuto;20190880]Once you switch to a heavier rocker, you have to determine whether or not stiffer valve springs will be needed.
The Ultra Pros are only available in 1.8:1 ratio from what I remember, so putting them on any cam over .590 lift will increase the lift to a point where a roller tip would be required in the first place.[/QUOTE
YT rockers are indeed heavier than Oem units but it’s the over the nose weight that matters. My YT rockers on my MMS 265’s are only 10 grams heavier over the nose, verses on OEM LS7 rocker. I’m very weight conscious and I weigh everything. I’m not going to get into a rocker arm argument here, but your “very heavy” statement could easily be misleading.
Old Jan 3, 2020 | 03:55 PM
00pooterSS's Avatar
Don't the stock rockers always wipe out the valve tip at over .62x lift due to scrubbing of the valve tip? Did they do anything on the BSR's to fix that?
I always thought the recommendation was to go roller tip over 620 lift..
Old Jan 3, 2020 | 06:25 PM
RonSSNova's Avatar
The YT’s were light when they first came out. But they began breaking. Happened to me. Motor with a busted exh rocker becomes very pissed off.
The design they have now is obviously heavier. I have them on my AFR headed LS1.
Seat of the pants said I lost power past 6500. Already had the better AFR Springs and titanium retainers.
They are noisy as well. No failures though.
THe BSR shaft setup looks nice. Personally, I’d add oil feed. Late model Hemi uses bronze bushed shaft rockers and I’ve never seen a failure.
Will be interesting how how they fare after time. Seems other solutions for the stock rockers end up with issues. I’m replacing my Comp trunions as we speak. Tooley V2 setup.
Ron
Old Jan 6, 2020 | 07:51 AM
Usually you are required to mill the rocker stands to change the geometry. I run .650" with stock rockers, no issues.
Old Jan 6, 2020 | 08:57 AM
Not everyone has the equipment to do that since it can't be done with a standard bridgeport, but it does work.
Lowering the rocker changes the peak lift valve-to-nose contact point putting it back in a safer area.
Old Jan 6, 2020 | 01:17 PM
00pooterSS's Avatar
Thanks for that info, didn't know people were doing that. Sounds like there is a bit of a market for a lower/shorter rocker stand
OP, you may wanna check the geometry or give comp a call and see if those BSR's are gonna work with your lift. If not, maybe the texas speed OE style rollers are the ticket.
Old Jan 6, 2020 | 01:39 PM
RonSSNova's Avatar
High lift cams have a smaller base circle, correct?
That would effectively move the contact pattern towards the heel of the rocker pad.
Old Jan 6, 2020 | 01:50 PM
00pooterSS's Avatar
Old Jan 6, 2020 | 02:02 PM
RonSSNova's Avatar
Are you talking about milling the stands in the cyl heads?
Or the stands that go between the head and the rocker?
Old Jan 6, 2020 | 02:18 PM
My setup has the removable stands milled.
Old Jan 6, 2020 | 02:23 PM
The removeable stands. You can't just mill them with a flat because of the alignment tabs on opposing corners. You use a CNC mill to remove material from the flat portion that sits against the head.
