scoggin dickey sd0130 ls cam
Old Feb 1, 2020 | 05:33 AM
Dice Auto's Avatar
Default scoggin dickey sd0130 ls cam
Hello guys just would like to ask if anyone here has used the Scoggin dickie sd0130 cam in a ls1 5.7, if so is there any videos that you can share with me, just would like to get a idea on idle quality, I know the tune plays a big game along with exhuast etc, I have had this cam on the shelf for years and would like to get a idea of sound along with idle note.
I am planning on using it on a twin gt3582r turbo's 5.7ls
Thanks in advance 🤙
Old Feb 5, 2020 | 02:42 AM
Dice Auto's Avatar
Default Bump
Any help would be appreciated.
Old Feb 5, 2020 | 02:43 AM
Dice Auto's Avatar
Default Bump
Old Feb 5, 2020 | 06:53 AM
99 Black Bird T/A's Avatar
Based on the part number provided I'm guessing this is the SDPC cam we're talking about.
I don't have the cam in question, nor would I use it in a NA 5.7 LS1. As stated its more of an LS3 cam designed around then needs of the LS3 head. This cam has 1 degree of overlap with the very wide 116 LSA so I'd expect idle quality to be good with quality tuning.
Without knowing your goals and planned set up its not really possible to toss out good alternative cam specs. With the twin turbo goal, i really have no idea of a good cam suggestion
SPDC can probably suggest a better cam matched to your goals or another cam vendor or cam guru like Cam Motion, Pat G, EDC and so on can.
Best wishes in your cam quest.
