Using thicker heads to make up for milling?
Old Feb 7, 2020 | 04:28 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Using thicker heads to make up for milling?
So... I am in the process of getting some used 60cc heads. Down the road some years, I want to add a Magnuson 2300. So... What are the pros and cons of using thicker head gaskets to make these 60cc heads. Like Comtec .075" to get back to close to stock.
Old Feb 7, 2020 | 04:35 PM
SLP IROC-Z's Avatar
Cant use a headgasket like that. Headgasket thickness should only be used for quench
Old Feb 7, 2020 | 08:48 PM
wannafbody's Avatar
Send a PM to MAVN, he's using .75 gaskets on one of his builds.
Old Feb 7, 2020 | 09:12 PM
RonSSNova's Avatar
It works just fine!
