Still have a misfire
Old Feb 18, 2020 | 05:35 PM
diver2522's Avatar
Default Still have a misfire
Hi all, I have a 2000 ls1, check engine light is on coming up as cylinder 2 misfire, changed injector, coil pack, plug, wire, compression test, checked for vacuum leaks, pulled valve cover off and everything looks fine, I'm out of ideas as to why it would still misfire, any help is greatly appreciated!
Old Feb 18, 2020 | 05:39 PM
Intermittent or constant?
Old Feb 18, 2020 | 06:03 PM
diver2522's Avatar
Definitely misses at idle but seems to go away as your accelerating but misses again in 5th gear doing about 45 mph, car is jerky when under a small load, give it gas and seems to clear up
Old Feb 20, 2020 | 06:26 AM
mintws6's Avatar
When was the last time you changed O2 sensors? if it idles relatively fine on a cold start and as it warms up starts to miss that could be your problem.
Old Feb 20, 2020 | 07:57 AM
Darth_V8r's Avatar
Moderator
May need to do a leak down on #2 to verify it holds compression
Old Feb 20, 2020 | 11:03 AM
diver2522's Avatar
Didnt notice any loss of compression with a compression test, let it sit for at least 5 mins and no loss on the guage
Old Feb 20, 2020 | 11:05 AM
diver2522's Avatar
But no check engine light code for an o2 sensor? Only code that comes up is p0302, definitely starting to be a mystery since everything is changed on that cylinder
Old Feb 20, 2020 | 11:21 AM
mintws6's Avatar
I have had O2's fail and not throw a code. If they are old its just something I would check. Fairly easy to do.
Old Feb 20, 2020 | 01:20 PM
Darth_V8r's Avatar
Moderator
compression tester gauge won't show pressure loss. It's designed to capture so after the test you can read it. Leakdown is different.
Old Feb 21, 2020 | 12:54 AM
diver2522's Avatar
Ill try a leakdown test next I suppose, changed both upstream 02's today and still misfiring ugh
Old Feb 21, 2020 | 07:16 AM
Darth_V8r's Avatar
Moderator
Yeah. O2 sensor affects all four on a bank not just one. For it to affect only one cylinder, it is either fuel, spark, or loss of compression. Or something really dumb like a wad of tape plugging the intake runner (highly unlikely)
Old Feb 21, 2020 | 08:09 AM
diver2522's Avatar
By the time I find the misfire I'm hoping it is something dumb lol, I'm going to try to do the leakdown test this weekend, just boggles my mind with everything that I've changed on that cylinder and it still misses on that cylinder, if the leakdown test goes good, then I'm totally lost lol
Old Feb 21, 2020 | 09:27 AM
mintws6's Avatar
If this problem is intermittent like you are saying then it couldn't be leak by right? like that would be constant I think it has to do with fuel if you checked your injectors, plugs and coils then I would check the O2's. Even if they are brand new sensors I've had them go bad. Does the car idle on cold start fine? and when it warms up starts to miss? That would also point to O2 sensors. Other thing would be to check wire harness that goes to #2 and see if it got wet or some kind of damage to it? Just throwing out ideas. Hopefully you didn't reverse the harness or something weird??
Old Feb 21, 2020 | 09:30 AM
mintws6's Avatar
I do agree with Darth though usually the code thrown from O2 would be a random misfire code and not just one cylinder but heck ECU is weird sometimes.
Old Feb 21, 2020 | 03:42 PM
Jays_SSZ28's Avatar
Can you take the spark plug out and post a good quality picture of it?
Old Feb 21, 2020 | 06:16 PM
88bruce's Avatar
Did you remove the intake manifold? A leaking intake manifold gasket will lean out the mixture
and cause a misfire at idle.
Old Feb 24, 2020 | 11:15 PM
diver2522's Avatar
I will do that sometime this week
Old Feb 24, 2020 | 11:17 PM
diver2522's Avatar
I never removed it, not sure if the previous owner ever removed it, would you maybe recommend spraying some throttle body cleaner around the gasket area? I've done it before and heard no change in the idle at all but can try it again
Old Feb 25, 2020 | 02:51 AM
88bruce's Avatar
There are eight separate intake manifold gaskets on the LS1, so it's possible just one could go bad.
Since #2 cylinder is on a corner, the intake manifold bolts may need to be retorqued.
Edit: Just to clarify, I'm not referring to the throttle body gasket. The intake manifold gaskets seal
the intake manifold to the ports on the cylinder heads. There are ten bolts attaching the intake manifold
to the engine.
Old Feb 25, 2020 | 07:21 AM
Darth_V8r's Avatar
Moderator
If your heads have been ported, it is also possible oil is leaking past the rocker bolt into the runner and oil-fouling the plug
