Spraying GM Performance MLS Gasket
I’ve read multiple post on spraying copper during head gasket installation and have a question about the procedure. If I choose to spray the new head gaskets, do I spray the entire front and back to include the rubber that is around the perimeter etc? Thanks for any responses in advance.
The question I have is...and we’ve talked about this before on Tech and gotten nowhere...has anyone ever had a MLS headgasket fail because it was sprayed?
That's the test we need to be able to prove what's best.
I got a 5 dollar bill that says it wouldn't have mattered. I venture to guess that 99.9% of the failures were in such a manner that spray wouldn't have changed a thing. It's just a sticky coating, what can it really do?
When I think on this subject I always think to myself that there are tens/hundreds? of thousands of LS motors that have been built in the last 20 years, all of them survived their standard duties without the spray. All of the performance builds I have been around did as well. And all the repairs I have done have held. And if they hold together with the spray and without, how will we ever know what's better.
Then going down the bunny trail further you think of the millions of engines out there that don't have copper spray on their headgaskets that out last the car they came in, and really start wondering..
But dont get all nervous, chances are if the block and heads are flat, you wont have a problem if you sprayed them. Its just not needed and the manufacturer doesnt recommend doing it....but I've never seen a gasket say not to do it either.
I was picturing standard issue LS stuff and other too close to stock type of stuff.
And like TTur said I could see it helping seal a very minor coolant seep.
But you open up the gap very much at all and nothing is gonna save ya lol. I feel that most scenarios out there are going to be a it's not gonna leak either way, or a whoopsie happened and spray or no spray aint gonna matter.
These engines can go 400,000 miles on the original non sprayed gasket. I've seen it.
You don't need to spray an ls engine head gasket unless you're building junk that should be resurfaced.
