243 not milled measurements?
Old Apr 15, 2020 | 01:50 PM
ffjosh's Avatar
Default 243 not milled measurements?
Trying to order a cam.
243 heads from valve cover surface to deck is 4.740 +- .003 from what I measured.
Looks like .01 was taken off.
am I right?
Old Apr 22, 2020 | 03:32 AM
ffjosh's Avatar
FWIW I bought a 232 234 .600 .600 cam
Clearance appears to be .110 and .130.
Old Apr 22, 2020 | 05:58 AM
WE TODD DID's Avatar
That’s plenty of clearance.
Old Apr 22, 2020 | 07:10 AM
gollum's Avatar
am I right?
Measuring from valve cover surface is not an accurate method to find out if heads have been milled. Maybe you could cc the heads with fluid to check (stock 243 heads are 65 cc I think)
Old Apr 22, 2020 | 10:11 PM
ffjosh's Avatar
I agree but I found the 241 measurements and went off that. At least kept me from going with a ms4 lol
Old Apr 23, 2020 | 12:48 PM
bubbaflaat's Avatar
Have you measured actual clearance? Is that the torquer v2 cam?
Old Apr 24, 2020 | 04:52 AM
ffjosh's Avatar
Yes cam is in and measured with dial calipers
