Do I need balancing
Old Apr 26, 2020 | 06:09 PM
DLT123's Avatar
Default Do I need balancing
Im new to this so please be easy on me. I've searched internet many times to not really find a answer. I have a 2005 5.3 L59 I tore it down today to find spun main bearing. The engine has factory gen4 Rods with factory dished floating pin pistons. The main on the block was worn bad so I bought a 2002 5.3 Lm7. If I use the rods and pistons from the L59 on the good Lm7 crankshaft will I need balancing? Engine will have a budget turbo setup with Elgin E1840P camshaft will be Partial daily driver and see the dragstrip every now and then.
Old Apr 26, 2020 | 07:31 PM
BCNUL8R's Avatar
I personally would not put an engine in my car that wasn't balanced. Even if all they did was check and confirm it was balanced it's money well spent in my opinion.
