Hone big end of rod.... surface rust
Old Apr 29, 2020 | 08:25 PM
VandykeT/A's Avatar
Default Hone big end of rod.... surface rust
I’ve got an ls1 that turned a bearing and destroyed 2 rods and the crank. I bought a reman crank and have extra rods but my extra rods have some surface rust. Would it be a bad idea to media blast (glass and low air pressure) the rust off and ever so lightly run a flex hone through the big end of the rod or should I look at finding 2 more rods that haven’t drawn moisture.
Old Apr 29, 2020 | 08:41 PM
stockA4's Avatar
Post a pic so we have a better idea. I've gotten away with using some pretty gruesome stuff but it's your engine so you have to live with your eye on oil pressure/temp gauges lol
That’s what any shop would do with them, so I’d say go for it. Make sure you clean them....and everything else....very well. It can be hard sometimes to get the glass media off of parts. It has a way of imbedding from time to time.
Old Apr 29, 2020 | 08:42 PM
WE TODD DID's Avatar
Will scotchbrite not remove it? The problem with honing is it makes the hole bigger, and changes bearing clearance. You also risk putting taper in the rod.
Old Apr 29, 2020 | 08:45 PM
stockA4's Avatar
I've actually used 00 steel wool, motor oil, and a little elbow grease many times over with great results
Old Apr 29, 2020 | 08:47 PM
RonSSNova's Avatar
Scotchbrite and WD40.
Should clean up fine.
Depending on your definition of surface rust.
Old Apr 30, 2020 | 12:09 PM
VandykeT/A's Avatar
I’ll get pictures a little later today. I blasted them and took 400 grit through it by hand. One rod has some small pits you can’t really feel. The other 2 I blasted looked good.
