What Heads with LS6 Cam?
Old Jul 16, 2004 | 12:42 PM
Dan's Avatar
Dan
Default What Heads with LS6 Cam?
Wondering what set of Heads would work good with the Ls6 Cam I am installing on my 98 Trans Am..I would like to keep the Stock Pushrod length 7.4 if possible. Thanks
Old Jul 16, 2004 | 01:00 PM
PREDATOR-Z's Avatar
AFR 205's
409rwhp with headers/induction/tune on a Z06.
Old Jul 16, 2004 | 02:30 PM
Gunnar@Patriot's Avatar
I would suggest our Stage II 5.3 heads with 2.02/1.57 and a 62cc chamber.
Only $1,295.00 at your local distributor!!
Old Jul 16, 2004 | 02:52 PM
gomer's Avatar
Since he's a 98, he might want to look at your $999 perimeter bolt 5.7 heads so he won't have to buy centerbolt valvecovers and later model coil pack brackets that would be required when running the 5.3 heads on a 98
Old Jul 16, 2004 | 03:35 PM
Dan's Avatar
Dan
That's what i want, Heads that will "Bolt Right in" with no modifications to any other areas
Old Jul 16, 2004 | 03:39 PM
PREDATOR-Z's Avatar
Then what Gomer said is the best.
I also read that TSP would do a $400 hand finish job on them (same as race their PP 5.3)
So for $1399 you would have a heck of a set that bolts right in.
