408 stroker lq4 block ls3 heads
Old May 17, 2020 | 11:49 PM
76dimepc's Avatar
Default 408 stroker lq4 block ls3 heads
So I’m rebuilding my 6.0 I got crank rods and -2.7cc cp pistons. top end I’m using stock 821 heads, at 70cc combustion chamber I should be at 11.1 cr (goal) I been searching a decent size cam for this setup since it’s going in my 76 c10. I want decent street manners and some get up and go without having to change out my 2800 stall so far I came up with these cam specs 232/240 610 114. Does this sound right
Old May 18, 2020 | 07:15 AM
Ls7colorado's Avatar
Would be ok but is a little big for 2800 stall in a 4000lb truck
Id stick with something along the lines of this https://www.summitracing.com/parts/sum-8714
But being a 408 and 11:1 compression you could still get away with the bigger cam just doesnt sound like you need it from what your gonna be doing with the truck.
