Nitrous on stock ring gap
Old May 18, 2020 | 10:48 PM
Camonly99transam's Avatar
Default Nitrous on stock ring gap
so I have a sbe ls1 with the stock rings and ring gap wondering how much nitrous I can spray an be safe was wanting to put 125 or 150 on it,an just put a set of ngk tr6 plugs in,will they work fine with that amount of nitrous?
Old May 19, 2020 | 01:17 AM
80/TA/LT1's Avatar
I’d roll with that, just make sure the timing is soft, and pull a plug or two after a pull to read it
Old May 19, 2020 | 10:49 AM
Jtm2085's Avatar
Stock ring gaps are fine as long as the tune is good. Dont use the tr6 as it is a projected plug. I would use br7s. Invest in a window switch, I would get a nos mini. It is a progressive controller that has a window switch built in
