Ls6 block 2003? Timing chain
Old May 26, 2020 | 03:28 PM
Gav's Avatar
Gav
Default Ls6 block 2003? Timing chain
Hello,
in middle of turbo conversion.
block is LS6 with 241 heads but maybe amissmatch of parts over time as still not sure where its originally from.
Question is as i think its an 03 block vin stamp, as i am upgrading to turbo low boost, should i replace the timing chain??
its a huge job to lift up engine as pulley fouls crossmember so would have to jack up engine to remove pulley to replace chain...
however i think its a two part timing cover but im guessing i cant replace the chain with (LS2 chain?) Just from removing the timing top cover....?
any advice greatly appreciated.
regards
gavin
Old May 26, 2020 | 03:48 PM
You need to be able to slip the chain over the end of the crank. So the front cover and oil pump come off.
How many miles on the chain?
Old May 26, 2020 | 04:00 PM
Gav's Avatar
Gav
Hello,
thats just it, i dont know....
engine dont use oil or anything though and it wont see a lot of miles
just going turbo though its been nagging me as ive replaced springs pac 1219 and intend to do better pushrods...its just the chain and oil pump...
regards
gav
Old May 28, 2020 | 05:15 PM
omc8's Avatar
Originally Posted by Gav
Hello,
regards
gavin
Vin stamp , post a pic of this Vin stamp !
Old May 28, 2020 | 05:48 PM
ddnspider's Avatar
If you're not pulling the front cover to do a pump or cam I wouldn't pull it specifically to do a chain. If you pull it to do a chain you better do a cam and pump while it's apart lol.
