Torquer V2 in a 6.0 Truck
Old Jun 8, 2020 | 04:28 PM
joejamesatou's Avatar
Default Torquer V2 in a 6.0 Truck
Looking to kick up the cam on my suburban. Currently running a BTR stage 3 truck cam in sig and will be most likely going to a Torquer V2 with 232/234 duration and .600 lift. 3200 rpm Circle D converter is going in. I'm thinking this should net around 25 horses up top and make it worth the while.Just don't want to go any crazier with the milled heads. Too much? Not enough?
Old Jun 8, 2020 | 06:14 PM
Tuskyz28's Avatar
Great cam choice!!
Old Jun 8, 2020 | 07:02 PM
Ls7colorado's Avatar
Might want a little more stall than 3200
Old Jun 9, 2020 | 07:24 PM
milkey57's Avatar
Had that cam in my truck. 3.73 gears and a 3600 stall. It was a blast to drive!
Old Jun 10, 2020 | 12:25 PM
00pooterSS's Avatar
I like it for a 6.0 but I'd probably pick a little bit higher stall speed, and I'd go for a low LSA if there's an option.
