Oil pump relief
Old Jul 12, 2020 | 05:42 PM
33willys's Avatar
Default Oil pump relief
Can the oil pump pressure relief valve be accessed with just the oil pan removed?
Old Jul 12, 2020 | 05:49 PM
Possibly, though it would be tight. Just looking at a pump pic, the relief valve plug is on the bottom opposite the pickup tube.
Why do you ask? If you don't mind...
Old Jul 12, 2020 | 05:52 PM
SLP IROC-Z's Avatar
Front cover and pan have to come off
Old Jul 12, 2020 | 06:11 PM
Well, there ya go. I wasn't sure, thanks for clearing it up.
Old Jul 12, 2020 | 06:39 PM
33willys's Avatar
My '05 LM7 is having oil pressure issues. Replaced the sensor and low oil pressure issues still there. Next step to to replace the O-ring and I thought, while there test the pressure relief valve if it can be reached. Guess that idea is out.
Old Jul 12, 2020 | 11:54 PM
chrisfrost's Avatar
Chances that some debris is holding the pressure relief just a smidge open are pretty slim. Generally if the pressure relief opens for a split second and does'nt close completely usually almost instantly wrecks rod bearings first followed by mains and cam if it's kept running that long . If its a high mileage engine then wear or debris certainly either could be an issue. I would say more than likely an pick up tube oring issue but yes alot of possibilities
Old Jul 13, 2020 | 08:31 AM
33willys's Avatar
Thanks for the feedback. Engine has "only" 100K on it and has been treated kindly with regular oil changes. I'm really hoping it is the O ring and will be able to give an update later this week.
