LM7 block differences to LS1
Old Jul 20, 2020 | 09:56 AM
Kingswood_76's Avatar
Default LM7 block differences to LS1
Hey guys, apart from the obvious aluminium vs cast iron difference and bore diameter, can anyone name any other differences in the block design?
I’m planning on building an ls1 (which I have) but using a cast iron lm7 block (1000+ Hp with boost) and just wondering if I’ll run in to any other anomalies between the two blocks. Thanks guys.
Old Jul 20, 2020 | 10:21 AM
Darth_V8r's Avatar
Moderator
External dimensions, bolt holes, thread patterns, all the same
Old Jul 20, 2020 | 10:46 AM
Thanks for a quick reply sir! oil galleries, oil path etc. the same do you know?
Old Jul 20, 2020 | 10:50 AM
Identical. They are the same basic design all the way through.
Old Jul 20, 2020 | 11:53 AM
ss.slp.ls1's Avatar
Same minus one bolt hole on the front of the block where the alternator bracket goes I think. The bracket will work without it but you could get the block drilled and tapped just in case.
