LM7 with flat top piston, balance issues
Old Aug 4, 2020 | 07:26 PM
Roy MacGregor's Avatar
Default LM7 with flat top piston, balance issues
First post, want to thank the forum as I have pulled so much info from old threads. But could not find this info. I have a LM7 that I’m putting 4.8 flat top pistons in. The 5.3 pistons + rings has a mass of 445 grams, The 4.8 flat top pistons +rings weigh 440 gram. Is there any benefits to have rotating assembly balanced, or just move on as I assume everyone else who asked this question on this forum has done
Old Aug 4, 2020 | 09:04 PM
5 grams isn't that much. Many have done this without balancing, but it would be better if you did.
Old Aug 5, 2020 | 10:15 AM
RonSSNova's Avatar
The pistons are the smallest portion of the balance. I think you will be just fine without balancing the crank
Old Aug 6, 2020 | 03:17 PM
ATK Engines's Avatar
You'd be surprised how much it actually takes to feel a vibration from a balance issue. You're looking at 30+grams to really notice a balance issue.
Old Aug 8, 2020 | 03:07 PM
tblentrprz's Avatar
So I've been wasting my $$ to balance within .5 gram and run 8000rpm?
Old Aug 8, 2020 | 04:20 PM
OP isn't running 8k RPM....
Old Aug 22, 2020 | 08:54 PM
rednari2's Avatar
Maybe I am misunderstanding this, but are you changing one or two pistons or the set. If its the set, then there is no issue. If it is one or two, five grams while not ideal should not throw it out of balance.
Old Aug 22, 2020 | 08:56 PM
rednari2's Avatar
Not at all.
