Fast 102 and prc heads port marching
Sanding rolls work better than cutters.
120 grit, and green and white buffing wheels. any videos on how they do it it? And do you touch the runners in side after you get it matched to the head?
I just went up a couple of inches. The runners aren’t real thick.
I marked the head and intake as well with alignment marks. The manifold can slide around a bit on the bolts.
