Been out of the game for a while. Need advice.
were the heads, the cam, lifters, pushrods, went back to stock rockers instead of the yella terra 1.8s, valve springs, 340 pump and obviously the tune. My injector duty cycle has gone up 10% since the change with the same target wot afr as before. These are 42lb ls3 injectors and 63psi of fuel pressure with the 340 pump compared to stock 58psi, they are peaking at 98%. The only downside now is under 2000rpm the power difference there is undeniable but this does not make the car drive bad. It has no issue maintaining speed on the highway in 6th gear even at 1500rpm, there is plenty of power to accelerate just not as much as before. I was able to tune out cam surge by reducing timing from 1400 to 1800 rpm. Both setups i have daily driven up to 1000 miles a week for long periods of time. The both are very similar on fuel with a slight advantage to the ls6 setup, this of course assuming sane driving. No doubt under heavy throttle the current setup will drink more fuel. I see alot of people say drivability will suffer well i can say ive gone from one extreme (stock heads and cam) to another (big cam and big heads) and id pick my current setup any day of the week over what i used to have. The trade off isnt drivability if the tuning is done right and the car is setup properly. The trade off in my situation is less power under 2000 rpm which does not bother me at all but on the other hand there is a big gain in performance from 3500 on up. The car is flat out way more fun to drive then before, the power is very impressive.
There are always going to be trade offs, even with a small cam. For instance a stock ls1 (smaller heads, less compression, smaller cam) is snappier and has the same midrange and more lowend torque than a stock ls6. But an ls1 makes makes 50 less tq and 50 less hp at peak rpms. Ive had both and with the right gears / converter you wont even notice the difference under the curve with the ls6 and in a drag race the ls1 wont stand a chance. Even on a road course the ls6 is preferred.
