Oil pressure problems LQ4
Old Oct 2, 2020 | 08:32 PM
Dmeeraz's Avatar
Default Oil pressure problems LQ4
Does anyone know if you can use a GM performance oil pump with a stock lq4 pick up tube? The pump is supposed to be off gen 4 LS engines and I got a different pick up tube seal for it. I have a 2004 lq4 so should I just use the orange thick seal? I think I might have to buy the pick up tube for 09+ trucks. Thanks in advance.
Old Oct 2, 2020 | 10:54 PM
All tubes fit in all pumps. O-ring depends on the tube, not pump. Thicker O-ring goes on tube with a groove rolled into it near the end, and thinner O-ring goes on tube with no groove.
