650hp NA 6.0 whos done it?
Old Oct 15, 2020 | 11:21 AM
Biebs's Avatar
Default Spin it up!!!
Originally Posted by NSFW
That's going to be a real challenge without an extra liter or an additional 2000 RPM. The liter would be a lot easier.
Yes turn it to 9000 or 9500 RPM you will be good!!!!
Old Oct 15, 2020 | 11:22 AM
HioSSilver's Avatar
Why limit it to 7000 rpm?
Old Oct 15, 2020 | 11:57 AM
helicoil's Avatar
The Wegner engines that powered the Nsscar series trucks were at 620-640HP with CNC'd 799 heads, lightweight valvetrain, moderate compression and not alot over 7000RPM. Pretty basic parts....
Old Oct 15, 2020 | 12:29 PM
Biebs's Avatar
Default Details matter!!
Are we talking engine on a Dyno HP or Chassis HP RWHP this make a huge difference!!!
Need the Thread starter to Clarify
Old Oct 15, 2020 | 07:01 PM
Corona's Avatar
Come on guys 650 rwhp with the parts listed ..
Old Oct 15, 2020 | 07:16 PM
Lsbmer's Avatar
Weld up the chambers or angle mill them. Haven't even reallly any thought into that yet. Maybe both.
But they will go 320cfm with a 2.04 valve. And more with bigger valve
Old Oct 15, 2020 | 07:30 PM
wannafbody's Avatar
Those Wegner heads were also 240cc heads
Old Oct 15, 2020 | 09:59 PM
Corona's Avatar
🤔 Do you know the cost of welding the chambers if not self done .... Angle mill sounds better👍
Old Oct 15, 2020 | 10:39 PM
Lsbmer's Avatar
I have a tig. I done it before.
But i still rather angle mill
Old Oct 16, 2020 | 02:09 PM
tberg725's Avatar
Originally Posted by Corona
Done Yrs ago.
Guys who say it can't be Done or need aftermarket this or that are so Full of BS. 👎
BTW with Factory Non ported Ls3 heads hydraulic cam with compression below 12.0
Fact. Add a little here and there 650 and running easy. New day updated parts #1 would be a good port job 🤐
🤘< Houston Baby
https://www.yellowbullet.com/threads...y-6-0l.449281/
I see more crap numbers made from them LS3 heads than I see good ones
Old Oct 16, 2020 | 02:55 PM
helicoil's Avatar
229cc
Old Oct 16, 2020 | 06:59 PM
  #32
Corona's Avatar
Cause your following and referring to P______'s = Kiddy 😼.
Old Oct 16, 2020 | 07:38 PM
  #33
Tuskyz28's Avatar
A highly respected legend in the LS game to me shrink down the valve timing events when using the L92/LS3 heads....
In other words people run a cam that doesn't hit the sweetspot in the heads or they simply don't turn the motor up. I see guys on here all the time running big runner heads and shifting at 6200 RPM 🤣.
Old Oct 16, 2020 | 08:19 PM
  #34
wannafbody's Avatar
229cc
Maybe I saw incorrect numbers.
Old Oct 17, 2020 | 12:50 PM
  #35
99 Black Bird T/A's Avatar
I think there's an early and later version of the Wegner NASCAR head.
Old Oct 18, 2020 | 02:06 PM
  #36
Lsbmer's Avatar
I didn't say any numbers.
if you dyno and and have alot sim experience you begin to trust it.
i use to literally have it running in the background while doing a pull.
i have a blue print of what i want now.
Now i just have to make it reality.
maybe 243 heads arent what i want.
i have alot of decions to make and more research on parts.
intake is going to be very important .
And rec port probably better choices there
