Small chamber cylinder head options
Old Oct 29, 2020 | 12:19 AM
Cwarta's Avatar
Default Small chamber cylinder head options
Been trying to find some small chamber aftermarket ls heads. Is there any company that makes them in a 52 ish cc range or close enough they can miller that far? I read somewhere the c5r heads are like 30cc?
Old Oct 29, 2020 | 12:36 PM
Bad346's Avatar
Have you considered a tfs 205 milled 35-40 thou?
Old Oct 29, 2020 | 06:49 PM
wannafbody's Avatar
Edelbrock 770469 might work for what you want.
Old Oct 30, 2020 | 02:28 PM
Ls7colorado's Avatar
JEEEEZ.... how does the air even make it out around the valves???
Old Oct 30, 2020 | 03:40 PM
00pooterSS's Avatar
Curiosity killing the cat gotta know, what are you building that needs that small of a chamber?
Can you not do this with a dome piston instead?
Old Oct 30, 2020 | 06:38 PM
dixiebandit69's Avatar
For real; I'd think that the shrouding on those chambers would outweigh any possible advantage of the bump in compression.
Old Oct 30, 2020 | 09:25 PM
Cwarta's Avatar
From what I read you have to hve the chambers machined in.
I have a dome piston and .060 milled 862 heads now, little over 14:1 comp.
Old Oct 31, 2020 | 04:05 AM
LLLosingit's Avatar
They are unported heads, You have them machined for your needs.
Old Nov 1, 2020 | 06:13 PM
WE TODD DID's Avatar
You’re going to need to start with a shallow valve angle head to get that without having to cut the decks to hell.
Old Nov 1, 2020 | 10:30 PM
Corona's Avatar
Different bore X stroke sizing available.
https://www.lsxceleration.com/mahle-...kit-930229665/
COMPRESSION RATIO W/ 65CC:14.2:1
Old Nov 4, 2020 | 08:53 AM
omc8's Avatar
If you going to run cathedral port intake you want to start with Edelbrock 619869 raw chambers 38cc
Old Nov 9, 2020 | 09:39 AM
Lsbmer's Avatar
Why would u want a dome.
Ive angled milled .120 and straight cut .030 same head and lost 0 flow
maybe loose low lift flow frpm sinking the valves . Steeper seats. But who cares
Anyone really think more flow at 100 and 200 lift add power?
