LS1 head bolt install.
Old Nov 9, 2020 | 07:40 PM
BaldEagleWS6's Avatar
Default LS1 head bolt install.
I’m doing HCI swap on my 98 TA, and trying to get the pass side head on, Anyone have issues with the AC/Heater Box being in the way from For the lower last head bolt? Budget wasn’t allowing studs so I purchased a set of Jegs Head bolts, and this is the last thing holding me up.
Old Nov 9, 2020 | 08:15 PM
How did you get the old ones out??? Reverse the procedure....
Old Nov 9, 2020 | 08:42 PM
cordless cutoff wheel.
Old Nov 9, 2020 | 09:11 PM
Before placing the head on the block, drop the bolts into the head bolt holes, then move the head over the block, clearing the bottoms of the bolts, then dropping it into position.
Old Nov 9, 2020 | 10:43 PM
bolt won’t thread into the block even with the head off. The heater box is taking up 1/8 inch I need to get the bolt in.
Old Nov 19, 2020 | 02:35 AM
slowpoke96z28's Avatar
Been wrecked before? There should be room. It would possibly be a PITA, but if you can get the left motor mount and/or mount stand out, loosen the trans mount, then that should let the motor tilt just enough to get the bolt in.
Old Nov 19, 2020 | 09:55 PM
1FastBrick's Avatar
Drop the cradle some an option?
