quick question about LS6 PVC conversion
Old Jul 19, 2004 | 12:23 AM
kossuth's Avatar
Default quick question about LS6 PVC conversion
I am converting the LS1 I have to a LS6 PCV system. Well, the guys that had the motor sitting in the shop sat the intake on the coolent vent tube breaking the spot weld. Figured just replace it. Well, I read on LS1howto.com that you can't use a LS1 coolant tube with the LS6 PCV conversion. The site didn't say so I'm gonna ask will a LS6 coolant vent tube fit underneath a LS1 intake manifold. I don't want to swap out the intake just yet, (using a C5 LS1 intake for the moment just to get the project up and running). Thanks for your help.
Old Jul 19, 2004 | 01:09 AM
Scott Turvey's Avatar
The LS6 coolant vent tube doesn't go under the manifold at all. It consists of two plugs for the rear holes in the heads, and a cross-tube for the front that has a 2-3" tee with rubber hose for connecting to the throttle body. you can convert to the LS6 coolant pieces before the manifold swap.
