Lm7 build
Old Dec 22, 2020 | 06:38 PM
Mapplin's Avatar
Default Lm7 build
I have a lm7 and I have 799 heads trying to get. To 11.1 c/r should I get dome pistons or flat tops and should I bore it to a ls1 5.7 I have a 1984 z28 that will only see the track
Old Dec 23, 2020 | 09:10 AM
AwesomeAuto's Avatar
799 heads on an LM7 will drop compression and you'll lose power over stock heads.
You can put some stock 4.8 pistons, or gen 4 5.3 rods and pistons in your LM7, with ported 862/706 heads that are milled, and get 11:1 fairly easily and it'll make a good bit more power than a stock LM7 with 799s.
