high compression questions
Old Jan 14, 2021 | 09:01 AM
  #41
Gunny57's Avatar
Originally Posted by MuhThugga
Not much of a cam card, then.
tell that to Texas Speed
Old Jan 14, 2021 | 12:48 PM
  #42
00pooterSS's Avatar
The TFS 220 as cast are really hard to beat power per dollar. They're excellent heads and lower cost than most out there.
Old Jan 14, 2021 | 02:26 PM
  #43
Bspeck82's Avatar
I have prc 225 as cast. They preform very well.
Old Jan 14, 2021 | 03:44 PM
  #44
showdog75's Avatar
I have Mamo 223 as cast. They work very well.
Old Jan 14, 2021 | 08:24 PM
  #45
Transamthunder's Avatar
I am looking at these heads as well for my boosted ls. They look like they have ports that are bigger than Hooker's giner after 10 kids. Bet they sound like a tugboat horn too if ya throw a lil compressed air accrossed them too.
Old Jan 14, 2021 | 09:22 PM
  #46
Gunny57's Avatar
the PRCs look really good especially with the hollow stem intake valves, thought about the TFS but hear their valves are boat anchors
Old Jan 15, 2021 | 06:35 AM
  #47
Bad346's Avatar
TFS will have Ferrea valves from factory, they are pretty high quality.
Old Jan 15, 2021 | 10:13 AM
  #48
swanny's Avatar
No problems here with my PRC 225's with hollow stems.
Old Jan 15, 2021 | 10:35 AM
  #49
64post's Avatar
Yes to11.6 scr with pump gas, I’m doing it with 91and without signs of knock retard with .036” quench, 045 head gasket and pistons .009” out.
Old Jan 15, 2021 | 10:47 AM
  #50
64post's Avatar
Forget fly cutting if you’re using OEM Hypereutectic pistons. Let’s see, you’re going to cut into already weak pistons making making them even weaker, they have no reinforcement under them for reliefs. I know there are people that do it but it’s NOT the way to go. Get 11 degree pistons if you’re using 11 degree heads and not worry about it. 11.5-12:1 is not hi compression, it’s moderate, 14:1-17:1 is high compression
Old Jan 15, 2021 | 10:55 AM
  #51
Gunny57's Avatar
there's a ton of people who have fly cut stock pistons with no ill effects, and I've seen a couple threads that illustrate that a lot of material can safely be taken out on an NA motor. I'm wanting a higher compression (higher in respects to most of the cars running around) street car that could be driven anywhere without worrying about e85 or race gas.
Old Jan 15, 2021 | 03:28 PM
  #52
RedXray's Avatar
I also have the PRC 225 heads with 62cc chambers .660" springs, flat tops with no flycut, 231/234 .629" .615" 111*
The PRC heads can use factory rocker arms while the TFS will need rollers if I recall correctly.
Nice pieces IMO
Old Jan 15, 2021 | 03:34 PM
  #53
Gunny57's Avatar
Nice pieces IMO
I believe I'll go with the PRCs with hollow stem intake valves, most of my stuff is TSP might as well go all the way
Old Jan 15, 2021 | 04:04 PM
  #54
RedXray's Avatar
I have the "Virus" edition heads lol
During the first round of stimulus TSP had them discounted 10%...
also bought the camshaft for only $300
To bad they're not having a sale this go round of stimuli
Attachment 712430
Old Jan 15, 2021 | 04:07 PM
  #55
Gunny57's Avatar
Oh wow that's wild, I missed that one. I wound up buying my cam and most of my stuff when they were doing black friday
Old Jan 15, 2021 | 09:02 PM
  #56
Bob570's Avatar
The TFS 220 can be had from BTR or Tick with powdered metal guides which will allow you to use factory rockers. That said, I went with PRC 225s and I'm very happy with them. The car got a lot faster.
Old Jan 17, 2021 | 10:46 AM
  #57
64post's Avatar
well, go ahead ad flycut, you’ll be lowering your static compression some and you’ll be out of balance some if you just cut without disassembly. Not a good idea if you have a choice, IMO
Old Jan 18, 2021 | 03:31 PM
  #58
00pooterSS's Avatar
I have GM as cast., They preform very well
Lol
Old Jan 18, 2021 | 06:14 PM
  #59
Gunny57's Avatar
Lol
lol same but I'm going to use those 243s in a different build and get the PRCs for my Hawk. still need a 4l80 and converter
Old Jan 18, 2021 | 08:32 PM
  #60
Lol
I just LOVE talking high preformance.....
