5.3 top of rear block
Old Jan 12, 2021 | 07:44 PM
BNRZ28's Avatar
Default 5.3 top of rear block
Did a search and couldn’t find anything but can someone tell me what this threaded hole is for on the back of the block passenger side close to the back of the head? Bought this block used and guy I bought it from couldn’t verify what year but said it was early 2000s block. I’m switching all my ls1 stuff over and I didn’t know if I missed something please let me know thanks
Old Jan 13, 2021 | 02:52 PM
BNRZ28's Avatar
Ttt
anyone ?
Old Jan 13, 2021 | 04:25 PM
00pooterSS's Avatar
Ground wire connection.
Go to this ad and look at the 3rd and 4th picture, use the zoom in feature
https://www.ebay.com/itm/2004-CHEVY-...gAAOSwWUJf27Pv
Old Jan 13, 2021 | 04:28 PM
00pooterSS's Avatar
Another
https://www.ebay.com/itm/04-CHEVY-EX...QAAOSwxjtfGzRx
Old Jan 13, 2021 | 04:31 PM
00pooterSS's Avatar
Better pictures of it in this ad
This engine has a single ground wire going to that location. The others look to have multiple, so it's going to depend on which harness you have if it connects there or not, or how many wires.
Look at the 9th picture and zoom in
https://www.ebay.com/itm/2003-2004-C...cAAOSwzlxfxqoL
Old Jan 13, 2021 | 04:50 PM
BNRZ28's Avatar
thanks for the pics and your time.
I have the factory 2002 fbody ls1 wiring harness and the grounds that I know of connect to the back of the heads. I should be ok right ??
Old Jan 13, 2021 | 04:52 PM
00pooterSS's Avatar
You're welcome.
And yes the F body grounds connect to the back of the drivers side head.
It really does not matter where you connect your ground break outs, as long as they are metal and clean and made of engine, and have conductivity to the main ground wire on the block, that comes from the battery.
You will be absolutely fine man, there are several bolt holes that are not used on different applications. I.E. you can have the same engine in multiple vehicles with several arrangements of which holes are used/not used.
Old Jan 13, 2021 | 04:54 PM
BNRZ28's Avatar
You're welcome.
yes sir I’m finding that out as I go. Thank for ur help
Old Jan 13, 2021 | 05:07 PM
00pooterSS's Avatar
No problem and good luck, engine looks clean, love the attention to detail
Old Jan 14, 2021 | 07:00 AM
BNRZ28's Avatar
thanks man it’s my first one every building it from the short block up.
Old Jan 14, 2021 | 12:45 PM
00pooterSS's Avatar
Looks like you're doing good man
What's the details on the build?
Old Jan 14, 2021 | 12:50 PM
BNRZ28's Avatar
dude I just looked back at the pics when u said attention to detail.. the bottom two pics are not my build lol. I’ve never seen those before at all lol idk how they even got there smh
and as far as my build it’s a built 5.3 (early 2000s) 799 heads with dual springs 9.8:1 compression ratio ljms 2 boost cam, ls6 intake, on3 turbo kit with pt88 t4 turbo ,it’ll have meth eventually and it’ll be on pump gas... trans is built th400 with PTC converter..
ive been following a lot of people’s builds on here as long as replicating my buddies build that sold me the turbo kit
Old Jan 14, 2021 | 12:52 PM
00pooterSS's Avatar
Sounds bad ***. What's it going in?
I only see 2 pictures, both with a red arrow pointing to the hole
Old Jan 14, 2021 | 01:02 PM
BNRZ28's Avatar
o ok cause on my end I see four pics two with the arrows and two of some random block and pistons lol like it’s the weirdest thing.
and it’ll be going in a 2002 fbody Camaro mostly full weight. I’d go e85 but the closest station one is 45 miles away
Old Jan 14, 2021 | 01:16 PM
00pooterSS's Avatar
Get some drums and fill them up and keep them at the house, race cars need e85!
I'm lucky. I have e85 6 miles from home and run it at all times
Old Jan 14, 2021 | 01:39 PM
Ls7colorado's Avatar
Kinda off subject but how long do you store the E85 for? Im doing a similar turbo setup to the OP and really wanna run E85 but the closest station is about 30mins away.
Sorry for hijacking lol
Old Jan 14, 2021 | 02:52 PM
BNRZ28's Avatar
haha right that would be awesome but to pay for 55 gallons at one time and haul it back would get expensive quick lol ya u r lucky man I wish we had some here
BNRZ28's Avatar
ya that would be nice to know too
Old Jan 15, 2021 | 01:10 PM
00pooterSS's Avatar
I store it for a week at a time, in my gas tank in my truck lol.
I don't have e85 at home, I have a gas station with e85 6 miles from home.
Old Jan 15, 2021 | 01:13 PM
00pooterSS's Avatar
I don't see why it wouldn't be fine to store it for at least a few months. I would get a fresh can, or plastic container for it. And keep it in the shade somewhere and away from a ton of moisture and out of the sun and it should hold fine if sealed well and in a clean container. I think the biggest issue with fuel sitting for long periods is when it sits in open air, or in really old fuel tanks and sits for very long periods of time. If it's sealed well it should keep far better.
These are all assumptions. But they seem to be good ones.....?
