Early vs Late gen3
Old Jan 25, 2021 | 06:53 PM
sargent11235's Avatar
Default Early vs Late gen3
Howdy guys,
Looking to buy some head studs but not sure what to get. I have the option of getting ARP 234-4316 (2003 and earlier) and ARP 234-4317 (2004 and later). I know my engine is a gen 3 because of the cam sensor location but not sure if it's a late model gen3. Are there any indicators that tell me what year my gen 3 is? I saw that you can measure the cam bearing but the bottom of my engine is already put together.
Thanks
Old Jan 25, 2021 | 07:29 PM
98CayenneT/A's Avatar
The difference is the earlier has 4 medium length bolts
Old Jan 25, 2021 | 07:56 PM
RonSSNova's Avatar
Pull one of the lower bolts out of what you have. If it’s about 6” long, it’s the early style.
Old Jan 25, 2021 | 08:15 PM
RedXray's Avatar
The earlier ARP bolts are about $70 more than the later equal length ARP head bolts (not sure about studs)
Look on the front of the engine block just below the bank 2 (pass) head for the date code.
My LQ9 came out of a 2005 Escalade with the engine code K134 and has equal length bolts.
K = November, 13 = Day, 4 = Year (November 13th 2004)
Attachment 712605
Old Jan 26, 2021 | 08:01 AM
Mine doesn't have a code in that location. It has a that little circle thing stamped in it. However, in the passenger side front of the block (opposite of where the 5.3 is stamped) it there is a stamp that says G14. I'm assuming that means G = July, 1 = Day, 4 - year.
Old Jan 26, 2021 | 08:23 AM
I just looked a little close and realized there is a date code although it looks altered. The day looks to be welded over... I guess I don't need it to figure out the date. Kind of weird. Thoughts? Thanks again
