Ls cam help
Old Apr 28, 2021 | 10:30 AM
leeparkhouse's Avatar
Default Ls cam help
Hi all.
After a bit of advice. I've been out of the ls scene for near 20 years.
I need some help specifically around cam choice. Back in the day the Trex and MS3 were 2 of the standout big cams that produced the goods. So what's happened in the last 20 years around big cams?
I'm after a big cam with big power from 3500-6800rpm. Car IS NOT A daily driver and I understand I'm going to have to run a big stall. Primarily cruising but more track and happy for the compromise of bad manners on the street. I'll be doing the heads and intake at a later date.
I'm chasing 400-420 hp or more if possible at the tires and I'm going use a set of Howard 1.71 rockers, new lifters, mellings oil pump, pushrods and double row timing chain , just as general maintenance.
Any help is appreciated
​​​​​Cheers
Lee
Old Apr 28, 2021 | 01:34 PM
Your best bet would be to tag up with one of the cam grinders that KNOW LS engines, like Cam Motion, Texas Speed & Performance, and Brian Tooley Racing.
Any one of them will steer you straight on a good LS cam.
Old Apr 28, 2021 | 08:22 PM
low2001gmc's Avatar
MASS seller approved
Ms3 and Trex (Pat G Version), along with the Polluter are still producing...
Old May 7, 2021 | 10:11 AM
PARMY's Avatar
Tick SNS stage 3
Old May 15, 2021 | 11:02 AM
Summitracing's Avatar
LS1Tech Sponsor
...and Summit’s cam experts have offered a lot of guidance over the last few years with the highest quality grinds at great prices lol.
Anyway, the Ms3 is certainly a legend and most of what has occurred since then is to develop lobes that are a little easier on the valvetrain to extend Rpm for more net area under the curve. Less valvetrain noise from easier exhaust lobe closing is a plus. It sounds like you are looking for something that’s more relaxed and not cantankerous at this point in your life and might enjoy a cam like the 222 duration Sum-8715R1. It makes most of the power of cams in the ms3 range with a mild idle. A LOT of power under the curve to match typical gear and converter means similar overall acceleration if that makes sense versus that narrow 6000-7000rpm range. This is just a starting point of course and can offer a Cam Motion, Btr, Pro Ls or just about any cam to dial them into your exact needs.
Old May 15, 2021 | 12:41 PM
Sorry Summit, I have GOT to keep you in mind when naming GOOD LS cam vendors! Your Ghost Cam, for just one example, is phenomenal!
Old May 15, 2021 | 02:42 PM
LS1Tech Sponsor
Ha, thanks G. We’re working pretty hard here for folks and we appreciate it. Have a good weekend!
__________________
800-230-3030
www.SummitRacing.com
Old May 15, 2021 | 09:46 PM
@Summitracing thanks for the info, appreciate it
 Michael S. Palmer
Old May 24, 2021 | 12:22 AM
Cody 06 gto's Avatar
Default I currently have stage 3 summit cam and want Lil more drivability
Should I step down to summit stage 2 or the ghost cam
Old May 24, 2021 | 01:43 AM
What is your setup?
The Ghost Cam IS surprisingly drivable considering the spec, but the 115LSA has a lot to do with it, cutting overlap a bunch compared to similar lift and duration cams.
