Comp BSR Rocker system install techniques?
When installing a single rocker arm I understand its Ideal to be on the camshaft base circle, then torque down to 22 ft lbs.
When installing the BSR rocker arm system this is impossible due to the design of the Shaft system.
What your thoughts are on how to torque these rockers down?
