Is this Excessive ring gap N/A
Old May 25, 2021 | 06:40 AM
boostedsquarebody's Avatar
Default Is this Excessive ring gap N/A
Hello all,
I have built my lq4 forged rod/piston short block for mild boost with ring gap coming in at .028in. Which would be grand for boost. However the budget is falling short right now and I’m wondering what would happen if I was to drop the motor in and run N/A for awhile?
also can someone plz explain whether or not I’ll need a pcv setup or just a vented setup? I assumed vented as the ring gap is big for N/A and I expect some blow by. I just wonder how detrimental this will be on horsepower.
Thanks
lq4 dish forged summit rods/piston (stock compression ratio aside from slightly milled heads) , stock crank, stage 2 summit turbo cam, 317 heads
Old May 25, 2021 | 06:53 AM
Originally Posted by boostedsquarebody
Hello all,
Thanks
At .028, you’ll notice nothing for power. Measurable on an engine dyno, maybe a few ponies, but it’s not a max-effort build it doesn’t sound like. You can vent either way.
Old May 28, 2021 | 07:30 PM
Sway Tale's Avatar
You will be fine. I have had engines with 0.050 to 0.090 and they made it to 150mph but anything over 0.045 starts guzzling oil and smoking off throttle.
