6.0 LQ4 Build
Old Jun 15, 2021 | 09:18 PM
mitchelc's Avatar
Default 6.0 LQ4 Build
Hey all, I’m getting an LQ4, possibly a LQ9 this weekend. It’s going in a 02 yukon
What should be the best build to get 400-450 RWHP! And N/A as well.
milled 317’s? I wanna go 54-469-11 cam, what else should I do head wise? Anything is welcome!!!
Old Jun 16, 2021 | 12:30 AM
Head-wise, you'd be better off switching to 243/799's and porting them, especially if it is an LQ4.
Old Jun 16, 2021 | 08:21 PM
RB04Av's Avatar
What he said about the heads. For a bigger cam especially, you need the higher compression. The stock LQ4 most particularly won't respond well as-is. The LQ9 probably doesn't even have enough compression in stock trim (317 heads).
That's A SHIPLOAD of cam. Also not ideal for any cathedral-port heads; it's set up for square-ports. Not really the right thing, unless you're planning on LOTS of nitrous.
For pure N/A, if you're willing to bite off on THAT MUCH cam, look at one more like about this, along with the later-model heads. https://www.texas-speed.com/p-1149-t...-camshaft.aspx
Old Jun 16, 2021 | 09:28 PM
Bspeck82's Avatar
Worked over 5.3 heads would work great as well. I'd go single pattern 228ish cam 112 lsa. Would make tons of torque for the truck.
