Throat size of 706 heads
Old Jun 22, 2021 | 10:47 PM
KCS's Avatar
KCS
Moderator
Wasn't the 706 head designed before the 243 casting?
From what I can tell, LM7 was introduced in 1999 and LS6 wasn’t introduced until 2001. I’m guessing all the cathedral port heads have the same throat diameter.
Old Jun 23, 2021 | 02:20 PM
omc8's Avatar
If it were me I would use a 1.95 intake valve for a number of different reasons but the biggest one to address the title of this thread throat size using 1.95 intake valve you can use the stock throat size untouched I believe REV and Si both make a 1.95 intake valve off the shelf . And yes you can make good gains with a 2-inch intake valve. And even with the smaller 1.89 stock valve good gains can be made with the right angles ......... take a look at what Lsbmer did with a 50° seat on the small valve in this old thread on the subject. https://ls1tech.com/forums/generatio...er-head-4.html
