Rocker arm torque specs.
Old Jul 11, 2021 | 01:06 AM
ramirop's Avatar
Default Rocker arm torque specs.
I’ve seen that rocker arms are to be torqued to 22 ft lbs. I’m running 225 PRC heads with a 224/228 cam, I upgraded the trunnions, and the bolt is a hex type. I followed the torque sequence of the rocker arms but I torqued the ******* to 24 ft lbs. did I over torque or am I fine since I’m not stock?
Old Jul 11, 2021 | 01:39 AM
Bob570's Avatar
It's fine, you're way over thinking. I bet most people don't even use a torque wrench when they put rockers on.
I used a Harbor Freight torque wrench when I did mine, I'm pretty sure I did like 25 ft/lbs.
Old Jul 11, 2021 | 11:09 AM
Cajun ELESS-ONE's Avatar
You are fine. The extra 2 ftlbs won't effect anything. These there is no lash settings on these motors. Your preload is achieved through pushrod length.
