Ignition Timing Tips
Old Jul 14, 2021 | 03:43 PM
TiHa's Avatar
Default Ignition Timing Tips
Hy Guys. I'm Tim from Germany. I swapped a Chevrolet LS1 in my BMW E30 Drift Car. Here's my Setup:
Engine LS1
MSD Atomic LS EFI Kit
LS2 Intake
92mm Fueltech Throttle Body
Injectors: 12569113
Coils: 12558948
MAP Sensor: 12614970
95 Octane Fuel
Cam (LS9 Specs): Intake Duration 211°, Exhaust Duration 230, Valve Lift 0.562" int/0.562" exh, Lobe Separation 122.5°
What would you say? It’s a Stock, Mild or Performance cam?
Which Ignition Timing do you can recommend with this cam? In the EFI Kit I can set ignition timing at idle, part throttle and wot.
I hope you can help me.
Old Jul 14, 2021 | 04:09 PM
That cam is better suited for a 6.2L supercharged engine. It is a stock LS9 cam that makes less power than the stock LS1 cam until about 5000RPM. The wide LSA is what's killing power.
Also, the LS2 intake is not optimum for that engine. An LS6 would do better.
Which ECM are you using?
Old Jul 14, 2021 | 11:56 PM
TiHa's Avatar
Thank you for your answer.
I use the MSD Atomic LS EFI Kit with computer.
Old Jul 15, 2021 | 10:17 AM
TiHa's Avatar
What cam would you recommend for me?
Old Jul 15, 2021 | 11:02 AM
Where do you want your powerband?
Old Jul 15, 2021 | 12:12 PM
TiHa's Avatar
Hmm it’s for drifting, I think in the middle and high revs.
Old Jul 15, 2021 | 01:12 PM
I would give one of our top cam grinders a call. Cam Motion, Brian Tooley, Texas Speed, etc....
Old Jul 17, 2021 | 07:57 AM
TiHa's Avatar
Ok thank you. I will do so 😊
 Michael S. Palmer
