Lq4 low oil pressure sometimes
at startup, it reads 45 psi of oil pressure, will drop to 35 at idle warm. However, when driving or getting into it a little bit, it will drop to 5 psi, and the low oil pressure light will flash. No noises in the engine. When I built this engine I replaced the oil pump and made sure the new oring wasn’t pinched and I used a new cam retainer gasket. What the hell could be the issue? It will read high and drop and never come back up. Now, I did see that this 2004 LQ4 I swapped into my 2002 Yukon had a small style oil pressure switch, shaped like a muffin. Does this style have the screen under it? Obviously I can’t see it because the engine is in. The new OPS is the taller version so it can work with my harness. Thanks!
